PowerTIG 250EX  Cooler and Cart Bundle Package, view 1
PowerTIG 250EX  Cooler and Cart Bundle Package, view 2
PowerTIG 250EX  Cooler and Cart Bundle Package, view 3
PowerTIG 250EX  Cooler and Cart Bundle Package, view 4
PowerTIG 250EX  Cooler and Cart Bundle Package, view 5
PowerTIG 250EX  Cooler and Cart Bundle Package, view 6
PowerTIG 250EX  Cooler and Cart Bundle Package, view 7
PowerTIG 250EX  Cooler and Cart Bundle Package, view 8
SKU# PT-250EX-BNDL-1
Analog AC/DC
$2,547.00
$2,024.00
Save - $523.00
Analog AC/DC
This Bundle package includes the PowerTIG 250EX, all of the standard accessories for the PowerTIG 250EX, PowerCool 401 water-cooler and the PowerCart 375LF. The PowerTIG 250EX and PowerCool 401 Water Cooler pair seemlessly together as an integrated system.
The PowerTIG 250EX stacks securely on top of the PowerCool 401 using a system of slide-on interlocking tabs. For a more permanent installation, the two units can also be fastened together using the side-panel screws and bracket, keeping them firmly connected during use and transport.
The 240V PowerCool 401 plugs directly into a dedicated power outlet on the rear of the PowerTIG 250EX, providing a clean and convenient installation without the need for a separate 240V wall outlet.
The PowerCart 375LF is tailored specifically to the frame of the cooler and welder package. It fits neatly without being undersized. A full size cylinder can be loaded as well. When the cart needs to resist rolling, two heavy duty locking casters lock the wheels on the front. The large 10" rear wheels also provide easy rolling on shop floors.
10,500 Watts Surge Rating
85V
240V 1 Phase
240V 3 Phase
TIG Max Inrush Amps (I1Max)
240V 1 Phase: 40 A
240V 3 Phase: 21 A
TIG Rated Effective Amps (I1Eff)
240V 1 Phase: 32 A
240V 3 Phase: 16 A
TIG DUTY CYCLE 240V 1 Phase
240V 1 Phase: 60% Duty Cycle @ 40°C at 250A/20V Rated Output
240V 1 Phase: 100% Duty Cycle @ 40°C at 200A/18V Rated Output
TIG OUTPUT RANGE 240V 1 Phase
240V 1 Phase TIG Amp AC Output Range: 5 to 250 Amps
240V 1 Phase TIG Volt AC Output Range: 10.2 to 18 Volts
240V 1 Phase TIG Amp DC Output Range: 5 to 250 Amps
240V 1 Phase TIG Volt DC Output Range: 10.2 to 18 Volts
TIG DUTY CYCLE 240V 3 Phase
240V 3 Phase: 60% Duty Cycle @ 40°C at 250A/20V Rated Output
240V 3 Phase: 100% Duty Cycle @ 40°C at 250A/18V Rated Output
TIG OUTPUT RANGE 240V 3 Phase
240V 3 Phase TIG Amp AC Output Range: 5 to 250 Amps
240V 3 Phase TIG Volt AC Output Range: 10.2 to 18 Volts
240V 3 Phase TIG Amp DC Output Range: 5 to 250 Amps
240V 3 Phase TIG Volt DC Output Range: 10.2 to 18 Volts
Stick DUTY CYCLE 240V 1 Phase
240V 1 Phase: 35% Duty Cycle @ 40°C at 200A/28V Rated Output
240V 1 Phase: 60% Duty Cycle @ 40°C at 160A/26.5V Rated Output
240V 1 Phase: 100% Duty Cycle @ 40°C at 130A/25.2V Rated Output
Stick OUTPUT RANGE 240V 1 Phase
240V 1 Phase Stick Amp DC Output Range: 5 to 200 Amps
240V 1 Phase Stick Volt DC Output Range: 20.2 to 28 Volts
Stick DUTY CYCLE 240V 3 Phase
240V 3 Phase: 35% Duty Cycle @ 40°C at 200A/28V Rated Output
240V 3 Phase: 60% Duty Cycle @ 40°C at 160A/26.5V Rated Output
240V 3 Phase: 100% Duty Cycle @ 40°C at 130A/25.2V Rated Output
Stick OUTPUT RANGE 240V 3 Phase
240V 3 Phase Stick Amp DC Output Range: 5 to 200 Amps
240V 3 Phase Stick Volt DC Output Range: 20.2 to 28 Volts
TIG Start Type
Lift Start With Remote
Start Amp Range AC
5-250A
Start Amp Range DC
5-250A
End Amp Range AC
5-250A
LCD SCREEN
End Amp Range DC
5-250A
0-10Seconds
0-25Seconds
USER INTERFACE
0-10Seconds
INVERTER TYPE
0-25Seconds
TIG Pulse
AC
Functions with Remote
AC Pulse Type
PowerSet Simplified Pro Setup
DC TIG Pulse Wave Shape
Square
Carbon Arc Capable
DC Pulse Frequency
0-500Hz
5/32"
AC Pulse Frequency
0-500Hz
Use 6011 for best results
10-90%
Pulse Amperage
5-95% of Welding Amperage
AC Frequency
20-250Hz
AC Balance
10-90% of Positive Electrode
IMPORTANT STICK SPECIFICATION NOTES
Not for E6010 use.
AC Wave Forms
Square
PowerSet (Simplifed Pro Set Up)
On-Arc
Cooler Control
Runs Continuously
.007" to 1/2"
.007" to 1/2"
.008"- 3/8"
*Capability is based on skill, and general welding knowledge. The maximum limit is a practical recomended limit based the industry standard of performing thicker welds with multiple passes.
1/16"- 5/32"
**Range of welding rod diameters is based of welding rod type and manufacturer's actual recommendations. Always consult manufacturer's recommendations for Amp range and minimum/maximum welding capability of each rod type.
  • Pipe and Structural
