Everlast RH-191 Argon and Argon CO2 Flow Meter/Regulator with 5/8 CGA Fittings and Gas Hose, view 1
SKU# EV-RH-191-CFH
Welder Gas Flow Regulators
€66.00
SKU# EV-RH-191-CFH
  • Unit Weight: 2 lb
  • Shipping Weight: 2.5 lb
  • Unit Dimensions: 4 in × 4 in × 7.99 in
The RH-191 flow meter uses billet brass construction and a familiar "floating ball" design which allows you to accurately set the gas flow rate. The unit has a main pressure gauge to monitor tank gas pressure. The floating ball floats up while gas is flowing and is a more accurate way of setting gas flow rate. The regulator has a dual scale with both Argon and mixed gas Ar/CO2 graduactions.
NOTICE: The floating ball type shows gas flow rate, only when gas is actively flowing. The ball will only float when the gas is flowing through the regulator. It will not float if the gas is not flowing. If the gas is not flowing but the ball is floating, check and inspect for leaks.
Key Specifications:
  1. Controls gas flow rates in excess of 60 cfh
  2. Gas hose included with standard 5/8CGA connector for the machine side for North American market
  3. Dual Scale for 100% Argon and Ar/CO2 gas mixes
  4. Rated for 3000 psi max.
