PowerTIG 200DV, view 1
PowerTIG 200DV, view 2
PowerTIG 200DV, view 3
PowerTIG 200DV, view 4
SKU# PT-200DV
PowerTIG 200DV
Analog AC/DC
$1,379.00
$1,079.00
Save - $300.00
PowerTIG 200DV
Analog AC/DC
SKU# PT-200DV
  • Unit Weight: 56 lb
  • Unit Dimensions: 9.5 in × 25 in × 14.63 in
PowerTIG 200DV
The PowerTIG 200DV is perfect for beginners and professionals who want a simple to use TIG weder without compromising welding performance. While the PowerTIG 200DV is not the most advanced unit Everlast offers, it checks all the boxes for the essentials needed for welding most daily shop chores up to 1/4". It features both AC/ DC TIG Pulse TIG welding capability, it also features stick welding capability as well. As a 200A TIG welder, the unit offers AC Frequency and Balance control in AC mode. These two features are essential to getting the most performance out of your machine. If welding at the limitsThe unit offers a pulse function as well for TIG in both AC and DC modes. The auto-sensing dual voltage 120/240V input allows the user to take the unit to the jobsite where there may not be 240V available. For stick performance, the unit performs well with titania and iron powder fluxed rods.
  1. Dual Voltage 120V/240V
  2. High TIG Duty Cycle: 200A @60%
  3. Pulse TIG up to 150Hz
  4. AC Frequency and Balance Control
  2. 8500 Surge Watts
  2. E6011 use is permissible
75V
75V
120V 1 Phase
240V 1 Phase
TIG Max Inrush Amps (I1Max)
120V 1 Phase: 35 A
240V 1 Phase: 31 A
TIG Rated Effective Amps (I1Eff)
120V 1 Phase: 24 A
240V 1 Phase: 23 A
TIG DUTY CYCLE 120V 1 Phase
120V 1 Phase: 60% Duty Cycle @ 40°C at 125A/15V Rated Output
120V 1 Phase: 100% Duty Cycle @ 40°C at 100A/14V Rated Output
TIG OUTPUT RANGE 120V 1 Phase
120V 1 Phase TIG Amp AC Output Range: 20 to 125 Amps
120V 1 Phase TIG Volt AC Output Range: 10.4 to 15 Volts
120V 1 Phase TIG Amp DC Output Range: 5 to 125 Amps
120V 1 Phase TIG Volt DC Output Range: 10.2 to 15 Volts
TIG DUTY CYCLE 240V 1 Phase
240V 1 Phase: 60% Duty Cycle @ 40°C at 200A/18V Rated Output
240V 1 Phase: 100% Duty Cycle @ 40°C at 160A/16.4V Rated Output
TIG OUTPUT RANGE 240V 1 Phase
240V 1 Phase TIG Amp AC Output Range: 20 to 200 Amps
240V 1 Phase TIG Volt AC Output Range: 10.4 to 18 Volts
240V 1 Phase TIG Amp DC Output Range: 5 to 200 Amps
240V 1 Phase TIG Volt DC Output Range: 10.2 to 18 Volts
Stick DUTY CYCLE 120V 1 Phase
120V 1 Phase: 35% Duty Cycle @ 40°C at 100A/24V Rated Output
120V 1 Phase: 60% Duty Cycle @ 40°C at 80A/23.2V Rated Output
120V 1 Phase: 100% Duty Cycle @ 40°C at 60A/22.4V Rated Output
Stick OUTPUT RANGE 120V 1 Phase
120V 1 Phase Stick Amp DC Output Range: 5 to 100 Amps
120V 1 Phase Stick Volt DC Output Range: 20.2 to 24 Volts
Stick DUTY CYCLE 240V 1 Phase
240V 1 Phase: 35% Duty Cycle @ 40°C at 160A/26.4V Rated Output
240V 1 Phase: 60% Duty Cycle @ 40°C at 130A/25.2V Rated Output
240V 1 Phase: 100% Duty Cycle @ 40°C at 100A/24V Rated Output
Stick OUTPUT RANGE 240V 1 Phase
240V 1 Phase Stick Amp DC Output Range: 5 to 160 Amps
240V 1 Phase Stick Volt DC Output Range: 20.2 to 26.4 Volts
TIG Start Type
Lift Start With Remote
Hot Start
Fixed
Start Amp Range AC
Fixed
20A
Start Amp Range DC
Fixed
5A
Arc Force
Adjustable
End Amp Range AC
Fixed
20A
Voltage Reduction (VRD)
End Amp Range DC
Fixed
5A
Anti-Stick Protection
0-10Seconds
0-25Seconds
Adjustable AC Balance
USER INTERFACE
Fixed
Adjustable AC Frequency
INVERTER TYPE
Analog Controlled IGBT
Stick Pulse
0-25Seconds
TIG Pulse
AC
Functions with Remote
AC Pulse Type
PowerSet Simplified Pro Setup
DC TIG Pulse Wave Shape
Square
On-Arc
On-Arc
Carbon Arc Capable
DC Pulse Frequency
150Hz
5/32"
AC Pulse Frequency
0-150Hz
Use 6011 for best results
10-90%
Pulse Amperage
5-95% of Welding Amperage
AC Frequency
20-250Hz
AC Balance
20-80% of Positive Electrode
AC Wave Forms
Square
PowerSet (Simplifed Pro Set Up)
Cooler Control
Runs Continuously
.007" to 5/16"
.007" to 5/16"
.025"- 1/4"
*Capability varies based on skill, weldment size and general welding knowledge. The maximum limit is a practical recomended single pass limit based the industry standard of performing thicker welds with multiple passes.
1/16"- 5/32"
**Range of welding rod diameters is based of welding rod type and manufacturer's actual recommendations. Always consult manufacturer's recommendations for Amp range and minimum/maximum welding capability of each rod type.
