PowerCool W350 (120V), view 1
PowerCool W350 (120V), view 2
SKU# PCW350-120
Water Coolers
$499.00
Water Coolers
SKU# PCW350-120
  • Unit Weight: 35 lb
  • Unit Dimensions: 10 in × 18 in × 14 in
The 120V PowerCool W350 is designed to work with non-Everlast welders and torches and is an affordable alternative to more expensive 120V brand coolers from other brands. These affordable coolers are a solid, reliable cooler cooler choice with copper core heat exchanger (radiator), stainless steel pumps with a brass impeller, and 5/8 LH standard compression cooler fittings that can fit most standard brand torches natively. The cooler comes with the left hand adapters included so it can be adapted to fit any torch. The cooler's flow rate is at a standard 1.1 liters per minute. With a two gallon capacity resevoir combined with the large heat exchanger, the welder can be used to cool torches up to 350A. A heavy duty pump and sealed industrial motor (made in Italy) are at the heart of the unit and designed for long life service. The beltless design puts the pump, fan and motor on a single shaft to improve reliability and reduce maintenance. There are no belts or pulleys to replace.
Notice:
Everlast is aware that some customers may be using various types of coolant in their PowerCool water coolers and with our NOVA or other brand TIG torches. These range from distilled water to Isopropyl alcohol to automotive type anti-freeze to R.V. anti-freeze to “private concoctions”. Since the PowerCool product line was originally released many years ago we’ve gathered valuable data and gained experience concerning the use of coolants and their impact on both the lifespan of the cooler and the TIG torches themselves. With that said, there are several areas of concern in regards to selecting the proper coolant. We have found that most popular alternatives fail to provide satisfactory performance. We have taken our findings and concerns and listed them below as basic elementary requirements needed for best performance and product life.
It is also for this reason, that coolers, torches, cables and related accessories will only be warrantied if used with commercial branded coolants made specifically for TIG or MIG welders.
Some commercial coolants for welder coolers are for use with MIG or Plasma only. Be aware and read the label because not all coolants are compatible for any process as some MIG coolants offer compatibility with aluminum water-cooled MIG gun parts. Some TIG coolants may work fine with some Plasma and MIG applications where no aluminum is present (except with push-pull guns) without crossover issues. Off-types, personal blends, and internet popularized alternatives can and will lead to damage or problems with operation. Be assured ignorning this will lead to problems down the road.
Yes, we know that commercial coolants are expensive. You will pay considerably more for 2 gallons of commercially branded TIG water-cooler coolant (the average required to fill one of our coolers) that a regular automotive type of coolant. At this point, after investing anywhere between $1500 to $5000+ dollars in a welding machine, cooler, and torches, this is a small price to pay and is what we feel to be a reasonable amount to protect a much more expensive investment. Warranty claims cost everyone money and time lost.
Answer: Distilled/De-ionized water, while non-conductive and fairly inoffensive as a possible coolant solution, does not provide algae protection, and requires frequent exchanging. It offers no lubricants or conditioner for the pump or torch hoses. Nor does it provide any anti-freeze solution. It is to be used only for testing, temporary, or emergency use. It should not be used for more than a period of three to four weeks before proper coolant is sourced and should be replaced. In and of itself, it will not damage the cooler, but distilled water does not promote maximum cooler protection noe offers best torch life. It does not protect the torch components from dry rot. Over time, due to contamination, it slowly becomes increasingly conductive. If for any reason the proper coolant cannot be found locally or ordered, and distilled or deionized water is the only option, be sure to exchange the water on a monthly basis.
Answer: While we are hesitant to endorse one product like this over the other or demand that any one brand of coolant be used, commercial brands like Prax-Air, Air-Gas, Miller, ITW, and Lincoln all provide satisfactory coolants that address the concerns above. There may be others. But extremely low priced coolants, or off brands may not not provide the level of protection required. Again, read the label before purchasing and using. Use due diligence in selecting your coolant.
NOTICE: THIS SUPERCEDES ALL PREVIOUS STATEMENTS AND ENDORSEMENTS MADE BY EVERLAST. IF AN EXISTING PRODUCT IS BEING USED WITH ANY COOLANT DIFFERENT FROM WHAT IS STATED ABOVE BASED OFF A PREVIOUS STATEMENT(S) MADE OR ENDORSED BY EVERLAST, THE WARRANTY WILL REMAIN IN EFFECT. HOWEVER, THE COOLANT SHOULD BE COMPLETELY REMOVED, PROPERLY DISPOSED OF AND UPDATED AS SOON AS REASONABLY POSSIBLE.
Input Voltage
120V
Input Amps
2.3A
Recommended Maximum Output Amperage
350A
Power Plug Type
15-50P
Cooler Flow Alarm
Type of Coolant Permissible
TIG or MIG
Pump Type
Industrial Vane-Type
Pump Construction Type
Stainless housing with Bronze impellor
Pump Output
1.1 LPM after bypass/ Max 45 PSI
Motor Type
Sealed Industrial
Heat Exchanger (Radiator) Material Type
Copper core with Aluminum Fins
Reservoir Size
2.0 gallons approximately
Torch Connection Type
Threaded LH CGA
Important Water Cooler Notes
Cooler comes with extra set of compression fittings to adapt to any torch.
