NOVA 26F Series Air-Cooled Flex-Neck TIG Torch 12.5 Ft 25 DINSE-Type Connector ( No Gas-Thru), view 1
NOVA 26F Series Air-Cooled Flex-Neck TIG Torch 12.5 Ft 25 DINSE-Type Connector ( No Gas-Thru), view 2
SKU# NVA-26F-125-UF-25QD
26 Series (200A Max)
€151.00
  • Unit Weight: 4 lb
  • Shipping Weight: 6 lb
The NOVA 26F Series Air-Cooled TIG torch (3.0 Version) features a flex neck design with improved durability and flexibility of the Ultra-Flex torch cables over previous Nova 1.0 and 2.0 versions. The new 3.0 torches feature larger head orifices for improved cooling and gas flow. New Food grade silicone torches are also used to be truly ultra-flexible. The torch design is of a universal WP- type TIG torch design which means compatible consumables are available at almost any local welding supply store that sells TIG accessories. The flex neck design flexes up to 40 degrees in the vertical plane to allow access to tight spots and to help reduce fatigue. (Keep under 35 degrees flex for maximum life.) It is rated for 200 Amps DC and 175 Amps AC use at 60% duty cycle. The traditional single line cable-in-gas-line design maximizes portabilty and reduces total weight thanks to the food-grade silicone based torch cables. While the torch can be used at higher Amperages, the user should be conscious of the limits of the torch. The 25 DINSE-Type power connector measures approximately 3/8" in diameter and fits under 200A units with the 25 DINSE connector. Measure before ordering. . NOTE: Measure inside female diameter of the machine-side power connector to confirm fit. DINSE 25 connectors are smaller and measure approximately 3/8" inside the female connector vs the DINSE 35 connector which is approximately 1/2" in diameter measurement . This is not a gas-valve torch.
175Amps
200Amps
TORCH NECK TYPE
Flex
TORCH SERVICE TYPE
TORCH HANDLE TYPE
TORCH REMOTE SWITCH INCLUDED
TORCH CABLE TYPE
Ultra-Flex (Silicone)
NUMBER OF MAIN CABLES
Single Line Air-Cooled
CABLE LENGTH
12.5Ft.
CABLE POWER ADAPTER SIZE/TYPE
DINSE 25 Type (Solid)
GAS CONNECTOR TYPE
