NOVA 17V Series Air-Cooled Gas-Valve TIG Torch 12.5 Ft. 25 DINSE-Type Connector (No Gas Thru) 17 Series, view 1
SKU# NVA-17V-125-UF-25QD
17 Series (150A Max)
€113.00
  • Unit Weight: 4 lb
  • Shipping Weight: 5 lb
The NOVA 17V Rigid Neck Torch uses a gas valve to manually control gas flow. This fits the Cyclone 200ES with DC Lift TIG function as well as the PowerArc 140ST unit with lift start. It is rated for 150A DC use and 120A AC use for medium to light welding. This torch is also called a "TIG-Rig" in the industry and is often used for lift start DC only TIG units without a gas solenoid. The gas line attaches direct to the gas regulator. This torch uses the smaller DINSE 25 (3/8" diameter pin on the power connector). This torch interchanges consumables with most standard WP-Type torches which can be bought in local welding supply stores, or here on this site. NOTICE: This unit comes with a quick connect coupling for gas, so it will need an additional quick coupling adapter to adapt to a gas regulator.
120Amps
150Amps
TORCH NECK TYPE
Straight/Rigid
Gas Valve
TORCH SERVICE TYPE
TORCH HANDLE TYPE
TORCH REMOTE SWITCH INCLUDED
TORCH CABLE TYPE
Standard (Rubber)
Ultra-Flex (Silicone)
NUMBER OF MAIN CABLES
Single Line Air-Cooled
CABLE LENGTH
12.5Ft.
CABLE POWER ADAPTER SIZE/TYPE
DINSE 25 Type (Solid)
GAS CONNECTOR TYPE
