TIG Button™ Amp Control Fits HTP Invertig 221 with 7 Pin Connector 25 Ft.
SKU# EV-TBS-S-HT-7
- Unit Weight: 1 lb
- Shipping Weight: 2 lb
This button fits HTP Invertig 221 with the pin connector.
7
| Connector PIN Count | 7
| Cord Length | 25Ft.
