TIG Button™ Amp Control Fits CK®/ Mr. TIG MT200 with 5 Pin Connector 25 Ft.
SKU# EV-TBS-S-CK-5
- Unit Weight: 1 lb
- Shipping Weight: 2 lb
This button fits CK/ Mr. TIG MT200 models.
| Connector PIN Count | 5
| Cord Length | 25Ft.
