TIG Button™  Amp Control Fits Thermal Arc/ SanRex 8 Pin Connector 25 Ft., view 1
SKU# EV-TBS-S-TA-8-8L
$285.00
  • Unit Weight: 1 lb
  • Shipping Weight: 2 lb
This button fits the following Thermal Arc® models with the 8 pin connector:
185, 185 TSW, 200 AC/DC, 201GTS
This button fits the following SanRex/Sanaarg® models with the 8 pin connector:
185P, 200 AC/DC
Connector PIN Count
8
Cord Length
25Ft.
