TIG Button™ Amp Control Fits Miller® Diversion with RJ45 8 Pin Connector 25 Ft.
SKU# EV-TBS-S-ME-8
- Unit Weight: 1 lb
- Shipping Weight: 2 lb
This button fits the following Miller® models with a RJ45 8 pin connector:
Diversion
| Connector PIN Count | 6
| Cord Length | 25Ft.
