TIG Button™ Amp Control Fits AHP® TIGs with 7 Pin Female Connector 25 Ft.
SKU# EV-TBS-AH-7
- Unit Weight: 1 lb
- Shipping Weight: 2 lb
This button fits AHP® models with a 7 pin male connector:
| Connector PIN Count | 6
| Cord Length | 25Ft.
