TIG Button™  Amp Control Fits Lincoln® S Series  6 Pin Connectors 25 Ft., view 1
SKU# EV-TBS-S-LE-6
$285.00
SKU# EV-TBS-S-LE-6
  • Unit Weight: 1 lb
  • Shipping Weight: 2 lb
This button fits the following Lincoln® models with a 6 pin connector:
Squarewave:
TIG 175
TIG 175 Pro
TIG 350
Connector PIN Count
6
Cord Length
25Ft.
