TIG Button™  Amp Control Fits Lincoln® R Series 6 Pin Connectors 25 Ft., view 1
SKU# EV-TBS-R-LE-6
$285.00
SKU# EV-TBS-R-LE-6
  • Unit Weight: 1 lb
  • Shipping Weight: 2 lb
This button fits the following Lincoln® models with a 6 pin connector:
Squarewave:
Tig 200 Tig 275, Tig 300, Tig 355
Invertec:
V160s, V160t, V200t, V250t, V275s, V300 pro, V350 pro
Connector PIN Count
6
Cord Length
25Ft.
