TIG Button™ Amp Control Fits Everlast® TIG welders with 7 Pin Female Connector 25 Ft.
SKU# EV-TBS-S-EVF-7
- Unit Weight: 1 lb
- Shipping Weight: 2 lb
This button fits the following Everlast® models with a 7 pin female connector
PowerTIG
Power i-TIG
PowerArc (with pedal control capability and connector)
Typhoon
| Connector PIN Count | 7
| Cord Length | 25Ft.
