TIG Button™  Amp Control Fits Most Miller® TIGs with 14 Pin Connector 25 Ft., view 1
SKU# EV-TBS-S-ME-14
$285.00
SKU# EV-TBS-S-ME-14
  • Unit Weight: 1 lb
  • Shipping Weight: 2 lb
This button fits the following Miller® models with a 6 pin connector:
Dynasty
Syncrowave
Maxstar 200 and up
Connector PIN Count
6
Cord Length
25Ft.
