RedSabre 6000X
SKU# EV-LRS-6000X-3-240480
As far as a hand-held laser goes, the power of the RedSabre 6000X ranks among the top hand held lasers in the industry. One of the biggest limiting factors of most lasers is wattage which helps to increase weld speed and penetration on thicker metals.
The new 6000 watt RedSabre advances the capabilities of compact industrial laser design to be able to exceed the 3/8" barrier of fusion depth in a single pass. At the 12mm limit (slightly under 1/2") this makes the RedSabre 6000X an elite status unit that can deliver high quality welds at this thickness. At maximum penetration, the weld width will be 8mm (approximately 5/16") which provides perfect weld buildup with the included wire feeder to form a strong weld that can hold up to any weld test when the weld is correctly.
RedSabre 6000X is designed for 3 phase 240V or 480V and comes with everything needed to get started except Argon or Nitrogen gas or MIG wire.
| Voltage/Phase | 240V 3 Phase
480V 3 Phase
| Maximum Wattage Output | 6000W
| Cooling | Refrigerated
