RedSabre 550, view 1
SKU# EV-LRS-550
RedSabre 550
$3,900.00
RedSabre 550
SKU# EV-LRS-550
  • Unit Weight: 62 lb
RedSabre 550
The new RedSabre 550 is a table-top model, which makes it the perfect compact air-cooled laser for portable operations. The air cooled design of the RedSabre is new and innovative way to cool lasers without heavy, large water cooling systems. Many Fiber lasers in this wattage range are heavy water-cooled lasers weigh over 3 to 4 times more. The high volume fan and high temperature diode design of the RedSabre 550 reduces the foot print of the welder. The ergonomic SUP33T gun design and safety features are hallmarks of the RedSabre model line.
Includes built-in touch screen color LCD controls.
Notice:
  5. The use of a laser in your business may require you to follow additional ANZI guidelines separate from the use of regular arc welders. It may also require special training and certifications that require additional investment and costs. In businesses with employees, you may be required to appoint a Laser Safety Officer with completed training and certification and additionally train individual operators and nearby individuals in laser safety and use.
FDA Accession #: 2420545-000
FDA Product Code: 95R--FF
240V 1 Phase
Gun Model Type
SUP33T
Gun Operation and Programming
Single Scan
Cooling
Air-Cooled
Optic Pump Manufacturer
GW
