RedSabre 3001X, view 1
RedSabre 3001X, view 2
RedSabre 3001X, view 3
RedSabre 3001X, view 4
RedSabre 3001X, view 5
RedSabre 3001X, view 6
RedSabre 3001X, view 7
RedSabre 3001X, view 8
SKU# EV-LRS-3001X-1-240
RedSabre 3001X
$22,999.00
$17,999.00
Save - $5,000.00
RedSabre 3001X
  • Unit Weight: 365 lb
RedSabre 3001X
Up until recently 3000 Watt fiber lasers were all water-cooled. This meant having large, bulky equipment to move around, sometimes weighing in excess of 750 lbs. However, concepts and applications of new technologies and developments in existing technologies have allowed the size and weight to be drastically reduced for this size of welder. The new RedSabre 3001X employs a novel method of cooling compared to the water cooled design: refrigeration. The refrigerated design reduces size and weight while improving cooling so that the units can run non stop for up to 12+ hours.
The ergonomic SUP33T gun is compact and powerful with excellent ergonomics.
Separate transformer required, but included. See wiring instructions pdf on this page.
For Manual Use Only. Not intended for automatic or computer controlled applications.
Notice:
  3. Use safety glasses only matched to the wave length of this unit. Other Specialized safety equipment is also required Do not use standard cutting shades or welding helmets while using this equipment. Use only safety eye and face wear rated for 1070 (+/- 10nm) nm wave lengths.
  4. The purchase of this laser welder with your local and state governments. Please identify any registration issues and concerns before purchase. Please contact your local and state governing authorities before purchase to inquire about registering your laser welders. Everlast does not maintain a list for each state, nor lists of general requirements for registration.
240V 1 Phase
Gun Model Type
SUP33T
Cooling
Refrigerated
Optic Pump Manufacturer
GW
