RedSabre 200CP, view 1
SKU# EV-LRS-200CP-240
RedSabre 200CP
Pulse
$15,658.00
$11,999.00
Save - $3,659.00
RedSabre 200CP
Pulse
  • Unit Weight: 65 lb
  • Unit Dimensions: 9 in × 24 in × 17 in
RedSabre 200CP
The 200W Pulsed Wave Laser Cleaner can carefully remove paint and descale material with ease without damaging or overheating the subsurface. The Pulse wave laser design of the unit can be fine tuned for the precise amount of paint, mill scale and rust removal. The pulse action is more forceful than a standard non-pulse laser cleaner, so less wattage needs to be used. The unit can also select for cleaning width and cleaning pattern shapes, which are useful for improving cleaning efficiency on different textures and shapes.
This model features a compact steel portable case with an easy to use detachable touch screen control. This unit is ideal for use in auto body and commercial shop operations where compact size and portability are important.
Gun Model Type
BWT20C
Maximum Wattage Output
200W
Cooling
Air-Cooled
Optic Pump Manufacturer
JPT
