RedSabre 1500X, view 1
RedSabre 1500X, view 2
RedSabre 1500X, view 3
RedSabre 1500X, view 4
RedSabre 1500X, view 5
RedSabre 1500X, view 6
RedSabre 1500X, view 7
RedSabre 1500X, view 8
SKU# SKU: EV-LRS-1500X
RedSabre 1500X
$9,999.00
RedSabre 1500X
  • Unit Weight: 300 lb
RedSabre 1500X
Laser technology is beginning to revolutionize the welding industry. Laser applications in the welding industry are evolving so fast that many major welding companies are having a hard time keeping up with it However, the need to stay current with Laser technology is clear because it has become not only become affordable, it changes in design and manufacturing of lasers have made them compact and practical even for small operations. Even so, some welding manufacturers have been slow or reticent to accept the new applications of Laser technology in the welding industry. However, in keeping with the heart of Everlast's policies to lead the way in the industry, Everlast has taken the lead by releasing a full scale production line with more laser related welding equipment than any other welding brand.
With the evolution of lasers and developments made in compact Fiber lasers, it has become very clear that Fiber Lasers are the future for precision welding of light to medium gauge metals. The pinpoint accuracy and speed at which a Fiber Laser can weld is stunning. New developments in technology haave also improved ergonomics and durability of the hand held laser guns and related equipment. Compared to old CO2 lasers, Fiber lasers are "light years" ahead.
New developments in fiber laser technology allows one machine to expertly handle many other welding related processes without adding a lot of extra machines or equipment. The RedSabre 1500X can weld, cut, and descale rust and paint with one machine, making a truly versatile multi-process machine. No extra purchases are necessary to do so. It includes all the attachments and lenses needed to adapt the machine to the process desired. The programming allows for Cutting, cleaning, passivation, and welding without any special updates or upgrades to the machine. All you will need to do is provide, filler wire (MIG type) shielding gas or compressed air (depending upon the process) to support the desired process.
The ergonomic gun is compact and powerful with a fatigue reducing gun handle angle and a molded grip.
Notice:
  5. The use of a laser in your business may require you to follow additional ANZI guidelines separate from the use of regular arc welders. It may also require special training and certifications that require additional investment and costs. In businesses with employees, you may be required to appoint a Laser Safety Officer with completed training and certification and additionally train individual operators and nearby individuals in laser safety and use.
240V 1 Phase
Cooling
Refrigerated
Optic Pump Manufacturer
GW
