RedSabre 1500, view 1
RedSabre 1500, view 2
RedSabre 1500, view 3
RedSabre 1500, view 4
RedSabre 1500, view 5
RedSabre 1500, view 6
RedSabre 1500, view 7
RedSabre 1500, view 8
RedSabre 1500, view 9
SKU# EV-LRS-1500
RedSabre 1500
$12,774.00
$9,999.00
Save - $2,775.00
RedSabre 1500
SKU# EV-LRS-1500
  • Unit Weight: 181 lb
RedSabre 1500
The new Red Sabre 1500 is a 1500 Watt, air cooled portable laser welder designed for compact size and portability. The air cooled design of the RedSabre is new and innovative way to cool lasers without heavy, large water cooling systems. Many Fiber lasers in this wattage range are heavy water-cooled lasers weighing 600 lbs or more. The high volume fan and high temperature diode design of the RedSabre1500 reduces the foot print of the welder. The ergonomic SUP33T gun design and safety features are hallmarks of the RedSabre model line. This model can Weld, Cut, and descale rust and paint.
Includes detachable touch screen color LCD controls and synchronizing wire feeder.
Notice:
  5. The use of a laser in your business may require you to follow additional ANZI guidelines separate from the use of regular arc welders. It may also require special training and certifications that require additional investment and costs. In businesses with employees, you may be required to appoint a Laser Safety Officer with completed training and certification and additionally train individual operators and nearby individuals in laser safety and use.
FDA Accession#: 2410134-000
FDA Product Code: 95R--FF
240V 1 Phase
Gun Model Type
SUP33T
Optic Pump Manufacturer
RLASER
