Red Sabre Quad Spool Laser Wire Feeder QW-FWS-04A
SKU# EV- QW-FWS-04A
- Unit Weight: 64 lb
- Shipping Weight: 69.98 lb
- Unit Dimensions: 9.8 in × 22.6 in × 26.4 in
he Red Sabre Quad-Spool Wire feeder is designed to work seamlessly with The RedSabre 6000 Laser Welder. The quad feeder can be operated in pairs or with all four feeders feeding at the same time. Upper and lower levels are switched on or off for double or quad feeding. Alternatively, only one feeder can be loaded to feed wire. The 4 roll drive system for each spool allows the unit to reliably feed wire to the laser torch head without issues. When all 4 wires are being fed, the laser can bridge larger gaps and can weld much quicker.
This unit includes control cable, nozzles and wire tubes for immediate setup and operation with the RedSabre 6000.
Specific technical information not listed in specifications:
Power Input: 240V
Input Wattage: 144W
Input Amps: 6A
Wire Speed Adjustment Range: 15-600 cm/min or 6- 236 IPM (display is in cm/min)
Standard Wire Size Range:
- Steel, Stainless V Type Groove: .8-2.0 mm (.030 to 5/64")
- Aluminum U Type Groove: 1.0-1.6 mm (.040 to 1/16")
| MAXIMUM WIRE FEED SPEED | 600 cm/min or 264IPM
| MAXIMUM SPOOL WEIGHT | 44lbs.
| SPOOL DIAMETER(S) | 12"
| DISPLAY | No Display
| NUMBER OF DRIVE ROLLS | Four
| DRIVE ROLL SIZES | .030"/.8mm
.040-/ 1.0mm.045
.045" (.047 or 3/64")/1.2mm
.062" (1/16")/1.6mm
