Quick Connect Male/Female Gas Kit 9mm/b-type Lincoln® Style 2PC
Gas and Water Quick Connect Fittings
$18.00
SKU# EV-9MM-GAS-SET
- Unit Dimensions: 3 in × 1 in × 1 in
This gas quick-connect set is the standard for all Everlast Welders with this type of connection. The female fitting replaces the unit side gas fitting. The male fitting can be used on any Everlast or other brand TIG gas or water line. The hose barb connection can be used with different types of hose clamps or any sleeve-crimp-on fitting. This fitting set is also perfect for connecting a 17V torch direct to a gas cylinder regulator. This setup is used in some Cyclone and Stick welders with Live-Lift TIG applications that do not use an automatic internal gas solenoid valve.
