PTM-100 CNC/Machine Torch Blow Back Start 25 Ft. Central Connector, view 1
PTM-100 CNC/Machine Torch Blow Back Start 25 Ft. Central Connector, view 2
SKU# EV-PTM100-25C
Blow-Back/Non HF
$679.00
Blow-Back/Non HF
SKU# EV-PTM100-25C
  • Unit Weight: 7 lb
  • Shipping Weight: 7 lb
  • Unit Dimensions: 24 in × 24 in × 3 in
The PTM-100 is a non-contact, blow back start style 100A rated machine torch with pilot arc designed for CNC and Automated cutting. Fits all Everlast plasma cutters with a Euro Central Connector. Natively fits PowerPlasma 100S, and 1022i plasma cutters. Consumables should be changed to fit the Amperage. Can be fitted with consumables ranging from 40-100A in capacity (1.0-1.5mm orifice). This type of torch uses the consumable shoulder to initiate the arc by "blowing back" the spring loaded consumable with air pressure during start to strike an arc. (This is the standard type start for most modern plasma cuttings systems under 150A.)
Torch Amperage Rating
100Amps
TORCH CONNECTOR TYPE
Euro-Central Connector
COOLING TYPE
Air-Cooled
