PowerCool W400 (240V)
SKU# PCW400-240
- Unit Weight: 40 lb
- Shipping Weight: 45 lb
- Unit Dimensions: 12 in × 24 in × 10 in
The 240V PowerCool W400 is designed specifically to stack under older large frame Everlast welders and all torches torches. It can be used as a stand alone cooler however, and can be used beside almost all Everlast TIG and multiprocesss units. This unit is designed to stack under older PowerTIG 400EXT, Power i-MIG 353DPi, Lightning MTS 275 and PowerMTS 400. On the PowerTIG 400EXT, Power i-MIG 353DPi, and Lightning MTS 275 models, the welders have a ready-fit plug in on the rear to power the coolers. The PowerMTS 400 will need a separate power outlet to supply 240V. These coolers are a solid, reliable cooler choice with copper core heat exchanger (radiator), stainless steel pumps with a brass impeller, and B-Type 9mm color coded cooler fittings that can fit Everlast brand torches and welders natively. The cooler flow rate is at a standard 1.1 liters per minute. With a two gallon capacity resevoir combined with the large heat exchanger, the welder can be used to cool torches up to 400A. A heavy duty pump and sealed industrial motor (made in Italy) are at the heart of the unit and designed for long life service. The direct drive means there are no belts or pulleys to service or maintain.
NOTICE: Everlast is aware that customers may be using various types of coolant in their PowerCool Water Coolers and with our NOVA or other brand TIG torches. These range from distilled water to Isopropyl alcohol to automotive type anti-freeze to R.V. anti-freeze to “private concoctions.” Since the PowerCool product line was released over 12 years ago we’ve gathered valuable data and gained experience concerning the use of coolants and their impact on both the lifespan of the cooler and the TIG torches themselves. With that said, there are several areas of concern that we look for in a coolant. We have found that most popular alternatives fail to provide satisfactory performance. We have taken our findings and concerns and listed them below as basic elementary requirements needed for best performance and product life.
The coolant provides satisfactory anti-freeze characteristics. While some may provide some sub-freezing characteristic protection, they do not provide enough or provide inconsistent sub-freezing protection. It also offers additional wetting and heat transfer characteristics, or at least doesn’t interfere with the water base level cooling ability. Not all anti-freezes are designed to improve cooling characteristics. It provides provides anti-algae conditioners as well. This helps to prevent torch plugging and blockage of lines, and narrow torch passages and reduces the need for frequent coolant exchanges and cleaning of torches. The shelf life of the Coolant is satisfactory. Coolant should last in a commercial environment without break-down, gassing off etc. for an extended period of time. That the Coolant is designed to be flowable for rapid recycle conditions. Some times of Coolant are for static or low flow conditions only. I.E. certain types of R. V. Coolant. That the Coolant not be conductive. Many automotive type coolants have certain conditioners and additives that make it electrically conductive. Conductive Coolants can make High Frequency starting more difficult as it tends to rob and dissipate the H.F. energy. Can also contribute to arc instability in general. That the Coolant be compatible with the common silicone, rubber, PVC formulations of the components found in our torch cables and most other brand torch cables on the market without deteriorating them. This is a large concern. Certain types of coolant can cause dry rot, premature aging, and leaks. Good coolants also provide conditioners expressly made for protection and conditioning of the components. That the Coolant be compatible with the materials found in the torch head such as brass, copper and solder without corroding the components. Good coolants also provide lubricity to the mechanical components without impeding flow or making it overly viscous. That the Coolant be compatible with all the materials found in the cooler, including copper, brass, PVC, silicone, rubber, etc., without leading to corrosion, deterioration or component failure. That the used Coolant be relatively safe, and not a severe hazard to the environment, or at least has safe disposal guidelines attached to it that can help prevent environmental damage. It is for these reasons, that Everlast is now recommending that customers ONLY use commercial brand coolants designed for use with TIG welders with a rating for use with High Frequency (H.F.). These coolants will usually include statements or information regarding the concerns listed above.
Answer: While we are hesitant to endorse one product like this over the other or demand that any one brand of coolant be used, commercial brands like Prax-Air, Air-Gas, Miller, ITW, and Lincoln all provide satisfactory coolants that address the concerns above. There may be others. But extremely low priced coolants, or off brands may not not provide the level of protection required. Again, read the label before purchasing and using. Use due diligence in selecting your coolant.
| Input Voltage | 240V
| Input Amps | 1.1A
| Recommended Maximum Output Amperage | 400A
| Power Plug Type | IEC 60320-1 C-13
| Cooler Flow Alarm | No
| Use With These Units | Older Power i-MIG 353DPi, PowerTIG 400 EXT, Lightning MTS 400
| Type of Coolant Permissible | TIG/MIG depending upon application.
| Pump Type | Vane Type
| Pump Construction Type | Stainless with Bronze impellor
| Pump Output | 1.1 LPM after by pass
| Motor Type | Sealed Industrial 240V Italian made
| Heat Exchanger (Radiator) Material Type | Copper core with Aluminum Fins
| Reservoir Size | 2.2 gallons approx.
| Torch Connection Type | Quick Connect Coupler
| Important Water Cooler Notes | Use only TIG rated (low conductivity) or MIG rated coolant (rated for aluminum parts)
