PowerCart 330 Heavy Duty Welding Cart with Single Cylinder Capacity
SKU# PC-330-HD
- Unit Weight: 112 lb
- Shipping Weight: 115.99 lb
- Unit Dimensions: 15.5 in × 42 in × 45 in
If you are looking for the best built cart out there for your welder, the PowerCart 330 is the cart you need. The rugged construction and heavy gauge components make the 330 cart ideal for not only Everlast, but also for other similarly sized welders. The PowerCart 330 is designed to fit most Everlast TIG welders with or without water coolers 330A and under. It also fits all stick welders 400A and under. It also fits all plasma cutters 150A or under. The cart can hold one full-size gas cylinder up to 9" in diameter. It has a foot pedal holder as well as space to stow your welding gear underneath. It's been picked as a favorite carts by Everlast's own crew.
Note: This cart will fit most Everlast MIG welders, but does not give easy access to the spool door. The welder will need to be removed to load a new spool.
| MAXIMUM GROSS WEIGHT CAPACITY | 400lbs.
| MAXIMUM CYLINDER SIZE SUPPORTED | 9"
| CASTERS/WHEELS | Yes, 2 Swivel and 2 Straight
