PowerCart 500 HD Welding Cart with Single Cylinder Capacity
Welding Carts (See Also Welding Tables)
$339.00
SKU# PC-500-ML
- Unit Weight: 68 lb
- Shipping Weight: 71.99 lb
- Unit Dimensions: 15 in × 41.5 in × 45.78 in
The PowerCart 500 is specifically designed to the Typhoon 500A. The design is rugged yet simple. The heavy duty casters with bearings are able to support up to 400 lbs. This is more than enough capacity to support the weight of the welder, water-cooler, and full size (9") gas cylinder. The large rear wheels allow the unit to roll over simple floor defects.
| MAXIMUM GROSS WEIGHT CAPACITY | 400lbs.
| MAXIMUM CYLINDER SIZE SUPPORTED | 9"
| CASTERS/WHEELS | Yes, 2 Swivel and 2 Straight
