Parker SGP 401 Water-Cooled Gun Push-Pull Gun (7 Pin) 25 Ft. Euro Quick Connect
SKU# EV-SGP401-24-W180-P10-80ER
- Unit Weight: 16 lb
- Shipping Weight: 18 lb
- Unit Dimensions: 24 in × 24 in × 3 in
The Heavy-Duty 400A Parker SGP 401A water-cooled push-pull gun natively fits new Cyclone 262i, 312i, 263Pi, 313Pi, 253DPi, 353DPI and 503DPi models. It also fits new-style Lightning 275/ 275P models as well as Thunder215 and 255 models that are push-pull capable. A water cooler is required to operate this machine. The Cyclone 353DPI and Cyclone 503DPi include a cooler and include a cooler outlet on the rear, but all other models will require a separate purchase and may require a separate cooler 240V outlet to be provided. It comes fitted with a .045" drive roll for feeding Aluminum. Additional Drive rolls available as an option. It can also be retrofitted to work with older Power i-MIG models that feature push-pull capability such as the Power i-MIG 253DPi and Power i-MIG 353DPi, This cannot be used on older Lightning or PowerMTS models. ThisPistol Grip gun comes the larger 7 pin connector and will require a 2 pin adapter to work with older Power i-MIG models mentioned above. This design allows Wire Feed/Amp control at the gun on all new models. Wire feed speed control on the gun is only supported on newer models. The speed control on older models will not work and wire speedcontrol must be controlled on the panel.
| CO2 Amperage Rating | 400Amps
| CO2 Duty Cycle @ Amperage Rating | 100%
| Ar/CO2 Amperage Rating | 350Amps
| Ar/CO2 Duty Cycle @ Amperage Rating | 100%
| GUN NECK TYPE | Straight
| STOCK DRIVE ROLL SIZE(S) | .045/.047"(3/64")/1.2mm
| AMP CONTROL TYPE | Amp/Wire Feed Control on Gun
| CABLE LENGTH | 25/8mFt./MetersFt./MetersFt./MetersFt./Meters
| CABLE CONNECTOR TYPE | Euro-Quick
