Parker DSP 360A Spool Gun 25 Ft. Euro Quick Connect
SKU# EV-DSP360A-24-P10-80ER
- Unit Weight: 10 lb
- Shipping Weight: 13 lb
- Unit Dimensions: 24 in × 24 in × 5 in
The Parker DSP360A is a heavy duty, 300A air-cooled spool gun that will run with the best of them. The unit features adjustable Wire Feed Speed/ Amp control on the gun and a 1000 hour life motor. The unit fits new Cyclone units and is recommended for all Cyclone (except E series), Hurricane, Lightning and Thunder Models over 200A max MIG output. Also fits former Power i-MIG 253DPi, 353DPi units with the optional 2 pin adapter (in this configuration, the wire speed/Amps are controlled on the panel, and not the gun). Not recommended for Cyclone "E" series Economy models.
This model ships with a .040" drive roll. Be sure to purchase additional drive rolls to fit the size wire you will be using.
| CO2 Amperage Rating | 320Amps
| CO2 Duty Cycle @ Amperage Rating | 35%
| Ar/CO2 Amperage Rating | 270Amps
| Ar/CO2 Duty Cycle @ Amperage Rating | 35%
| GUN NECK TYPE | Straight
| STOCK DRIVE ROLL SIZE(S) | .040"/1.0mm
| AMP CONTROL TYPE | Amp/Wire Feed Control on Gun
| CABLE CONNECTOR TYPE | Euro-Quick
