NOVA™ Wireless Pedal For Miller­®/Hobart® Pedal With 14 Pin Connector (RFCS 14/14HD), view 1
NOVA™ Wireless Pedal For Miller­®/Hobart® Pedal With 14 Pin Connector (RFCS 14/14HD), view 2
NOVA™ Wireless Pedal For Miller­®/Hobart® Pedal With 14 Pin Connector (RFCS 14/14HD), view 3
NOVA™ Wireless Pedal For Miller­®/Hobart® Pedal With 14 Pin Connector (RFCS 14/14HD), view 4
SKU# NVA-FT06-MLR14
Fits Select Miller®/Hobart® Models
$449.00
SKU# NVA-FT06-MLR14
  • Unit Weight: 4.5 lb
  • Shipping Weight: 6 lb
  • Unit Dimensions: 8.6 in × 5.7 in × 3.5 in
The NOVA™ rechargeable wireless pedal offers up to a 100ft operating range away from the power source for situations where long distance operation is required. The impact resistant polymer pedal is tough and resilient and can withstand the rigors of an industrial shop or jobsite. The 120/240V convenient charging system charges quickly, with each full charge lasting up to 40 days, even during heavy 10 to 12 hour shift work. The Lithium batteries are robust and can handle up to 300 recharge cycles. If and when the common type lithium rechargeable battery packs do reach their useful life span, they can be replaced economically. The unit's transmitter is pre-synchronized to your specific pedal. Up to 50 NOVA pedals can be used in the same location. If the need arises, the transmitter and receiver can be re-synced easily. The 2.4 GHz transmitting dongle is powered by 120V for easy connection to common 15 amp power plugs. The magnetized dongle can be attached to the side of the welder for convenience. The pedal has a metal frame internally and is supplied with a high strength magnet which allows the pedal to be attached to anything metal for fast and easy storage. This pedal is a good option to replace Miller® and Hobart® RFCS 14 and 14HD pedals (P/N : 043554, 194744). Keep in mind, that the transmitter isn't battery powered and a separate connection to 120V will need to be supplied to the dongle. The unit comes with an 18 month warranty.
Connector PIN Count
14
