NOVATru-Fab 48"X48"X36" Stationary Welding Table
SKU# NVA-TBL-484836-F203805012
- Unit Weight: 400 lb
- Unit Dimensions: 48 in × 48 in × 36 in
The NOVA Tru-Fab 48"X48"X36" Welding Table is a basic but sturdy welding table, good for general layout and welding purposes for both professionals and avid home users. The station includes 4 sturdy leveling legs with a thick gauge tube construction. and includes a rectangular tube frame that supports the table and keeps the table from deflecting under load..
The heavy-duty Blanchard ground table top is 12mm thick (.47") is accurate and flat ( target: <or = to .002 per 24") for general purpose layout and welding and uses standard 5/8" holes on 2"x 2" standard spacing. The surface is nitrided (HV500) to a depth of .2mm and features a black-oxide finish which minimizes reflectivity and helps prevent spatter from sticking. The steel table top is made from Q355 steel (equivalent to ASTM A572 Gr50). The tubing frame adds additional rigidity and strength to the top. The table is rated for a weight up to 2000 lbs.
To get you started, there are two optional NOVA tool kits available. Of course the 5/8 "laser cut holes support many other brands table tools and tool kits.
| MAXIMUM GROSS WEIGHT CAPACITY | 2000lbs.
| TABLE TOP THICKNESS | .47" (12mm)
| MAXIMUM CYLINDER SIZE SUPPORTED | (Qty.1) 300 Cu. Ft. or (Qty. 2) 125 Cu. Ft.
| TABLE HEIGHT | 36
| TOOL HOLE SPACING (CENTER) | 2"
| TOOL HOLE SIZE | 5/8
| ADJUSTABLE HEIGHT | Yes
| CASTERS/WHEELS | No
| TOOL KIT INCLUDED | Optional
