Fab-Rite Professional Portable Welding Station
SKU# FR-2436-STN
- Unit Weight: 130 lb
- Shipping Weight: 140 lb
The Fab-Rite Professional Welding Station is a ideal solution to meeting your work station needs. The unit is equally suited for production facilities, fabrication and repair shops, or in welding schools. It's also perfect for home hobby users who need a protected area to work. The rolling-caster design and pop-up nature of the surrounding protective arc-shield panels make it easy to store when not in use. When done using, simply fold it down, and roll it in the corner.
The unit includes a two slide-in fabrication surfaces. The first choice is heavy bar grating for general purpose welding and cutting purposes. The second is a standard fabrication top with 5/8" holes on 2" spacing for light to medium duty fab work. Or it can be easily fitted with the material top of your own design.
A generous-sized sliding catch tray traps slag, rod stubs, and general welding waste. On each side of the panel, there are two additional recessed trays on either side that are of the welding top to hold consumables and/or prepped parts.
Sturdy Pop-up and hinged panels surrounding the unit's base include an installable back sliding curtain (not pictured) to provide a 360 degree flash protection to bystanders. The front and two side panels are equipped with shade 8 rated windows for general work monitoring of welding activities on three sides. Shade 13 protection is also available at view points along each side for concentrated viewing for instructional activities or QC oversight.
The Fab-Rite booth is designed with a vented storage area underneath that is designed for the optional Cyclo-Air@750-BT air filtration system. (See optional accessory in pictures above.)
The fold up top steel panels are fitted with shade 13 equivalent impact resistant windows for viewing. This is perfect for educational and quality control applications
- Portable base with Casters
- Can be used permanently or in temporary situations
- Designed for at -station fabrication and production of parts and assemblies
- 2 drop in work tops included: Heavy bar grating for general purpose or 5/8" x 2 for light fab
- Side trays for holding prepped parts/consumables/equipment
- Slide out catch drawer catches drops, sparks and debris falling through grating
- Popup/removeable shielding panels are hinged for fast set-up
- Shade 8 built in panels for general viewing/Arc flash protection
- Shade 13 observation points in panels
- 24"x36" total work area
- Back sliding curtain for full surround arc flash protection
- Can be used with the optional cyclo-air air filtration system (sold separately)
| MAXIMUM GROSS WEIGHT CAPACITY | 500lbs.
| TOOL HOLE SIZE | 5/8
| ADJUSTABLE HEIGHT | No
| TOOL KIT INCLUDED | No
