Everlast 18 Series Water-Cooled Amp Control TIG Torch 12.5 Ft. 35 DINSE-Type Connector (No Gas Thru)
SKU# EV-18-AMP-CNTRL-15
- Unit Weight: 16 lb
- Shipping Weight: 16 lb
The Water-Cooled Everlast 18 Series Amp Control torch allows amp control in combination with the 2T/4T controls on the welder. Recommended for Typhoon welders. Other units the torch may only work in 4T mode. It is designed to signal the upslope and downslope cycles, as well as the arc start and termination separately from the Amp adjustment. The torch has a rigid (fixed, non flex) neck design. The torch features separate on/off button along with a rotating North/South Amp control wheel built into the torch body. The Euro torch handle allows a comfortable grip. This torch is only designed for slight modification to Amperage while welding. It is not meant as a substitute for a foot pedal, since it has a separate torch switch that must activate and terminate the arc. This type of separate torch switch arrangement means that the adjustment of the amperage should be done before starting the weld rather during welding. It is not meant to roll-on and roll-off the Amperage while welding.
| AC Torch Amperage Rating | 250Amps
| DC Torch Amperage Rating | 350Amps
| TORCH NECK TYPE | Straight/Rigid
| TORCH SERVICE TYPE | Standard Service
| TORCH HANDLE TYPE | Euro
| TORCH REMOTE SWITCH INCLUDED | Yes
| TORCH CABLE TYPE | Standard (Rubber)
| NUMBER OF MAIN CABLES | Three Line Water Cooled
| CABLE LENGTH | 12.5Ft.
| CABLE POWER ADAPTER SIZE/TYPE | DINSE 35 Type (Solid)
| GAS CONNECTOR TYPE | Quick Connect (Type B, 9mm)
| WATER CONNECTOR TYPE | Color Coded Quick Connect (Type B, 9mm)
