Cyclone Wire Feeder (Water-Cooled) FCS-203-ACWC For Power i-MIG 353 DPi
Single Spool MIG Wire Feeders
$699.00
SKU# EV-FCS-203-ACWC
- Unit Weight: 45 lb
- Shipping Weight: 48.98 lb
- Unit Dimensions: 24 in × 10 in × 16 in
The FCS-203-ACWC wire feeder is designed to work with the Power i-MIG 353DPi welder. Water cooled connections help connect the MIG gun to the water cooler without having to use extensions. The cooler connects direct to the rear of the wire feeder via the water cooler umbilical lines supplied with the cooler. The wire feeder also has spool gun and push pull gun capability. The feeder may be operated with water cooled or air cooled torches.
| MAXIMUM WIRE FEED SPEED | 600IPM
| Amperage Rating | 400Amps
| Duty Cycle @ Amperage Rating | 100%
| MAXIMUM SPOOL WEIGHT | 44lbs
| SPOOL DIAMETER(S) | 12"
| NUMBER OF SPOOLS | One
| DISPLAY | No Display
| NUMBER OF DRIVE ROLLS | Four
| STOCK FEEDER DRIVE ROLL SIZES | .035"/.9mm
.040-/ 1.0mm.045 .045" (.047 or 3/64")/1.2mm
.062" (1/16") /1.6mm
| SUPPORTS GUN TYPES | Spool Gun
Air-Cooled Push Pull-Gun
Water-Cooled Push-Pull Gun
Air-Cooled Standard MIG Gun
Water Cooled Standard MIG Gun
| MAXIMUM RECOMMENDED OPERATION DISTANCE FROM POWER SOURCE | 75Ft./Meters
| COMPATIBLE WITH | Everlast
| MAIN CASE MATERIAL TYPE | Steel
| TYPE OF OPERATION (S) | Manual
