Cyclone Wire Feeder FCS-203-AC For PowerMTS 400
Single Spool MIG Wire Feeders
$519.00
SKU# EV-FCS-203-AC
- Unit Dimensions: 24 in × 10 in × 16 in
The FCS-203-AC wire feeder is designed to work with the PowerMTS 400 welder. The wire feeder has spool gun and push pull gun capability.
| MAXIMUM WIRE FEED SPEED | 600IPM
| Amperage Rating | 400Amps
| MAXIMUM SPOOL WEIGHT | 44lbs
| SPOOL DIAMETER(S) | 12"
| NUMBER OF SPOOLS | One
| DISPLAY | No Display
| NUMBER OF DRIVE ROLLS | Four
| STOCK FEEDER DRIVE ROLL SIZES | .035"/.9mm
.040-/ 1.0mm.045 .045" (.047 or 3/64")/1.2mm
.062" (1/16") /1.6mm
| SUPPORTS GUN TYPES | Spool Gun
Air-Cooled Push Pull-Gun
| MAXIMUM RECOMMENDED OPERATION DISTANCE FROM POWER SOURCE | 75Ft./Meters
| COMPATIBLE WITH | Everlast
| MAIN CASE MATERIAL TYPE | Steel
| TYPE OF OPERATION (S) | Manual
