Cyclo-Air S750, view 1
Cyclo-Air S750, view 2
Cyclo-Air S750, view 3
Cyclo-Air S750, view 4
SKU# EV-CAS750-BT
Cyclo-Air S750
Fume Extractors
$1,599.00
Cyclo-Air S750
Fume Extractors
SKU# EV-CAS750-BT
  • Unit Weight: 65 lb
  • Shipping Weight: 75 lb
  • Unit Dimensions: 17 in × 22 in × 17 in
Cyclo-Air S750
The work place is no place for dirty air. Work place air quality suffers in most welding shops and OSHA frowns upon poor air quality at the work place. As a conscientous business owner, there's little choice to make the work place air safe to breath. Everlast's Cyclo-Air S 750 can help you bring your facility into compliance and help alleviate air quality safety concerns so that workers can breath better, cleaner air.
The small 60 lb. unit includes wheels for portability and a fume funnel and positionable hose so that the welding fumes can be removed directly at the source. A three stage filtration system assures 95% filtering efficiency, resulting in cleaner filtered air that also cuts down on dirt and dust in the environment. The Cyclo-Air air filtration unit is variable speed so that the perfect amount of air flow can always be achieved.
The Cyclo-Air S750 moves up to 750 cubic meters per hour (approximately 440 cubic feet per minute) of air volume for rapid evacuation of welding fumes. If fume extraction MIG guns are used, the Cyclo-Air S750 can be connected to the Gun to pull fumes away from the work before they have time to enter the general area.
The unit is designed to fit into our welding booths and is perfect for production facilities and welding schools with assigned work stations. Noise is low at only 76dB at full fan speed. If the unit becomes plugged with dust or soot, the unit features a fused protection to prevent damage to the motor.
Voltage Input/Phase/Hz
120/240V 50/60Hz 1 Phase
Amps Input on Rated Input Voltage
300W (approx) input
Number of Filters/Stages
3
Filter Type(s)
mixed cleanable/replaceable
Decibel Rating
76
Air Flow (Rate or Volume)
750/m3/h or 244 cu3 ft./min
Variable Speed
HEPA
Optional
Source or Zone/Central Capture
Source
Cord Length
6 Ft.
Extraction Hose Length
8 Ft.
