AW3000 Plasma Cutter Regulator for PowerPlasma 82i and 102i
SKU# EV-AW3000-02
- Unit Weight: 2 lb
- Shipping Weight: 2.5 lb
This plasma cutter regulator is designed to regulate air pressure and flow before it enters the plasma cutter. It is designed to work with the PowerPlasma 80S/82i and 100S/102i units. This unit has a separate hole for an optional external pressure gauge. If no pressure gauge is used, the hole should be plugged with a brass plug (Pressure gauge and brass plug can be purchased separately under the parts category). The regulator also serves as a water trap to stop larger droplets of water from entering the plasma cutter's cutter air line that may result from the coupling/decoupling process of the quick connect air line fitting. The water trap is not meant to serve as a stand alone air dryer. A separate air dryer should be installed upstream of this unit. Mounting bracket not included.
