510 Series MIG Gun 3m 10ft., view 1
510 Series MIG Gun 3m 10ft., view 2
SKU# SN-510-3E
Conventional
$319.00
Conventional
SKU# SN-510-3E
  • Unit Weight: 7 lb
  • Shipping Weight: 10 lb
The North 510 series MIG gun from Everlast interchanges with similar 501 or 510 series guns from other manufacturers. Designed for serious use. Requires water-cooler. Recommended for any 350A and up Everlast MIG unit and any other brand with an Euro Style -Quick connect connector and water cooler capability . Recommended up to 500A use. Comes installed with .047-.062" aluminum (graphene) liner installed. Steel liner available. Not recommended for wires smaller than .040". For best operation, use a liner that is sized for the wire you are using.
CO2 Amperage Rating
550Amps
CO2 Duty Cycle @ Amperage Rating
100%
Ar/CO2 Amperage Rating
500Amps
Ar/CO2 Duty Cycle @ Amperage Rating
100%
GUN NECK TYPE
Curved
GUN SERVICE TYPE
Heavy Duty Service
GUN HANDLE TYPE
Ergonomic
STOCK LINER WIRE SIZE
.047” (3/64”) to .062” (1/16”)
LINER TYPE
Graphene
LINER COLOR
Black/Charcoal
CABLE LENGTH
10/3Ft./Meters
CABLE CONNECTOR TYPE
Euro-Quick
WATER CONNECTOR TYPE
