SKU# PT-315LX
IGBT Type: | Module IGBT |
Inverter Type: | Digital/Micro-controlled |
Output Type: | A D |
Voltage/phase: | 220/240 V 1 PHASE |
Max Rated TIG Amps: | 315A |
Max Rated Stick Amps: | 250A |
TIG Amps @ Rated Duty Cycle: | 3 2 |
Stick Amps @ Rated Duty Cycle: | 2 2 1 |
Max Inrush ( I1MAX ) Amps: | 2 2 2 |
Maximum Rated (I1EFF ) Input Amps: | 2 2 2 |
OCV: | T S |
TIG Output Range DC: | 5A-315A/10.2V-22.6V |
TIG Output Range AC: | 20A-315A/10.8V-22.6V |
Stick Ouput Range DC: | 20A-250A/20.8V-30V |
Stick Hot Start Amps: | 0-100% |
Stick Function: | Adjustable Arc Force Control |
Stick Hot Start Type: | Adjustable Hot Start |
6010/Cellulose Capable: | Yes |
Minimum Amp DC TIG Start: | 5A |
Minimum Amp AC TIG Start: | 20A |
TIG Start Type: | H L HF and Lift Start |
HF and Lift: | HV Start (Solid State HF Type) |
Memory: | No |
Upslope Time: | 0-15 Seconds |
Down Slope Time: | 0-30 Seconds |
Preflow time: | 0 |
Post Flow Time: | 0-30 Seconds |
TIG Pulse: | Yes |
Standard DC Pulse Frequency: | .2-750Hz |
Standard AC Pulse Frequency: | .5-750Hz |
Pulse Time On (Duty Cycle): | 10-90% |
Pulse Amp Range: | DC: 5-315A (AC: 20-315A) |
AC Frequency (Hz): | 20-500Hz |
AC Balance Range: | 10-90% |
AC Wave Forms: | A |
Remote Control: | 2T/4T |
Foot Pedal: | Standard |
