$0.00
Go to Checkout
SKU# EV-TMP-401-480V
Tempest 401i
MIG/DC TIG/Stick
$3,799.00
$3,599.00
Save - $200.00
Tempest 401i
MIG/DC TIG/Stick
The all new Tempest 401i MIG package is a true industrial power source type of unit.  The welder's design features tough IP23 ingress protection standards, potted boards and internally durable construction make this a true jobsite machine, whether in the shipyard or out in the field.  The welder can weld MIG, DC scratch start TIG, Stick and also features an air carbon arc gouge function for heavy duty gouging.  The size of the power source means that it can be carried anywhere or be used in "Power Racks" on skids if needed.  The wire feeder is a heavy 500A wire feeder with the capacity to feed wire over 850 IPM (22m/min).  With the optional longer umbilical, the wire feeder can be used up to 75 feet away from the main power source. For Air Carbon Arc Cutting/Gouging, just connect your favorite gouging torch and select the setting and you are ready to go. The unit does come with an accessory package for MIG, TIG and Stick welding.
Type:  Analog IGBT Inverter
Output /Process Type:  M D D
Voltage/phase:  480 V 3 PHASE
Max Rated MIG Amps:  400A
Max Rated TIG Amps:  400A
Max Rated Stick Amps:  400A
MIG Amps/Volts @ Rated Duty Cycle:  400A/34V @ 60% @ 104 F° (40°C)
TIG Output Amps/Volts @ Rated Duty Cycle:  400A/36V @ 60% @ 104 F° (40°C)
Stick Amps/Volts @ Rated Duty Cycle:  400A/36V @ 60% @ 104 F° (40°C)
Max Inrush ( I1MAX ) Amps:  480V: 16A
Maximum Rated (I1EFF ) Input Amps:  480V: 12A
OCV:  72V
MIG Output Range:  60-400A/17-34V
TIG Output Range :  30-400A/21.2-36V
Stick Output Range:  30-400A/21.2-36V
Variable MIG Inductance/Stick Arc Force Control:  Yes
Spool Gun Capable:  No
Pulse:  No
Standard Drive Roll wire size:  .040” and greater
Separate wire feeder:  Yes
Number of Drive rollers:  4
Max Wire Feed Speed:  850 IPM/22m/min
Max Wire Roll Diameter:  12” (full size up to 44lb)
Memory:  No
Upslope Time:  No
Down Slope Time:  No
Preflow time:  Auto
Post Flow Time:  Auto
Flux Core:  Y O
Air Carbon Arc:  Yes
2T/4T /Torch latch/Trigger:  Yes
Other Features:  Wire Jog
5 year
