SKU# SU-206SI
IGBT Inverter Type: | MOSFET |
Voltage/phase: | DUAL VOLTAGE 120/240 1 PHASE |
TIG output type: | DC only |
TIG Start Type: | High Frequency Only |
Pulse: | No |
Plasma Cutter Arc Start Type: | High Frequency |
PilotArc: | Yes |
OK-to-Cut Indicator/Low Air pressure safety: | No |
OCV: | T S P |
Max Inrush ( I1MAX ) Amps: | @ @ |
Maximum Rated (I1EFF ) Input Amps: | @ @ |
TIG Output Amps/Volts @ Rated Duty Cycle: |
120V:
240V:
Stick Output Amps/Volts @ Rated Duty Cycle: |
120V:
240V:
Plasma Output Amps/Volts @ Rated Duty Cycle: |
120V:
240V:
TIG DC Amp/Volt Range: | 1 2 |
Stick Amp/Volt Range: | 1 2 |
Plasma Amp/Volt Range: | 1 2 |
Preflow time: | Fixed |
Post Flow Time: | Fixed |
OverCurrent Protection: | Yes |
Duty Cycle Protection: | Yes |
Air Pressure OK Safety Indicator: | No |
Stick Arc Force Control: | Auto-Adaptive |
Torch Type: | Everlast AG-60 High Frequency |
Recommended Cutting Air Pressure: | 55-60 psi |
Recommended Compressor Capacity: | 4CFM@90 psi/ 20 gallon tank |
Downloads
