SM100N Spool Gun
Spool Guns
SKU# EV-SM100N
SM100N Spool Gun is designed to fit Cyclone 140E and 200ES units with Euro-style Connector. Can be used with older Power i-MIG 140E and 200E welders. Rated for 135A with 35% Duty Cycle, which is comparable to other guns this size. Serrated drive roll feeds 40XX and 50XX series aluminum wire. Can be used to feed flux core wires. Euro-style Connector connects to the gun connection on the welder. Common type consumables interchange with similar "SP-M8" type guns. Roll diameter max: 4". 20 ft. cable for extended length welding when standard gun is not long enough. The motor power connector that connects the control wire for the 140E/200ES to the welder is pre installed. Use with .030"-.035" diameter wire (use .035" for aluminum for best results) See through plastic cover allows you to view wire roll and remaining wire without opening side cover. Good for welding metals between 1/8" to 3/16" (140E). Up to 1/4" max (200ES) Recommended for current models: Cyclone 140E Cyclone 200E(S) Recommended for Older: Power i-MIG 140E Power i-MIG 200E
