$0.00
Go to Checkout
SKU# PU-206PI
PowerUltra 206Pi
IGBT Analog DC
$719.00
$539.00
Save - $180.00
PowerUltra 206Pi
IGBT Analog DC
SKU# PU-206PI
  • Unit Weight: 38 lb
  • Unit Dimensions: 16 in × 13 in × 7 in
As a much improved replacement for the long running PowerUltra 205P, we think you will find that the PowerUltra 206Pi is ultra useful around home shops and small garages as an all around DC welder and plasma cutter combination.  The new digital control is more reliable and easier to maintain.  But the unit still retains that analog feel, so it is easy to setup.  We've added a couple of new features to this unit, which improves the usefulness of the TIG function.  The unit now includes down slope and postflow control.  The welder side of the unit features DC output in TIG and Stick modes and is useful for welding all types of metals except aluminum and magnesium.  In TIG mode the unit features a simple to use pulse with a .5 and 25 hertz fixed setting. The additional pulse settings have been optimized for all around use, so you don't need to worry about alot more than turning the pulse on, selecting the frequency at which you want to weld, and start welding.  The plasma cutter can handle all types of metal and can regularly cut plate metal up to 3/8" thick with a clean cut capacity of up to 3/4".  If you are looking for a simple solution to your steel and stainless welding and cutting needs, the PowerUltra 206Pi offers a compact and economical alternative to purchasing separate separate units.
IGBT Inverter Type:  IGBT
TIG output type:  DC only
TIG Start Type:  High Frequency Only
Pulse:  Y F
Plasma Cutter Arc Start Type:  Blow Back (Piston type)
PilotArc:  Yes
OK-to-Cut Indicator/Low Air pressure safety:  Yes
OCV:  T S P
Max Inrush ( I1MAX ) Amps:  @ @
Maximum Rated (I1EFF ) Input Amps:  @ @
TIG Output Amps/Volts @ Rated Duty Cycle:
@ 120V:
  • 1
  • 1
@ 240V:
  • 2
  • 1
Stick Output Amps/Volts @ Rated Duty Cycle:
@ 120V:
  • 1
  • 8
  • 6
@ 240V:
  • 1
  • 1
  • 1
Plasma Output Amps/Volts @ Rated Duty Cycle:
@ 120V:
  • 2
  • 2
  • 2
@ 240V:
  • 5
  • 4
  • 3
TIG DC Amp/Volt Range:
@ 120V:
  • 5
@ 240V:
  • 5
Stick Amp/Volt Range:
@ 120V:
  • 5
@ 240V:
  • 5
Plasma Amp/Volt Range:
@ 120V:
  • 2
@240V:
  • 2
Down Slope Time:  0-10 Seconds
Post Flow Time:  0-50 Seconds
OverCurrent Protection:  Yes
Duty Cycle Protection:  Yes
Air Pressure OK Safety Indicator:  Yes
TIG Pulse Frequency:  Fixed 1 or 25 Hz
TIG Pulse Time On:  Non-Adjustable
TIG Pulse Amp Range:  Non-Adjustable
Stick Arc Force Control:  Auto-Adaptive
Torch Type:  S-45 Blowback start
Recommended Cutting Air Pressure:  65-75 psi
Recommended Compressor Capacity:  5 CFM @ 90 psi/ 30 Gallon tank
5 year
