$0.00
Go to Checkout
SKU# PT-400EXT-240
PowerTIG 400EXT
Digital AC/DC
$2,899.00
$2,099.00
Save - $800.00
PowerTIG 400EXT
Digital AC/DC
SKU# PT-400EXT-240
  • Unit Weight: 120 lb
  • Unit Dimensions: 26 in × 20 in × 11 in
If you need the most power the PowerTIG 400 EXT is the latest and most powerful member of Everlast's PowerTIG series of TIG/Stick welders. With 240V single phase power, it delivers a full 400A in TIG mode, thanks to it's constant-on, high output fan cooling. That's enough power to weld most every TIG welding chore found in most any shop and do it without stopping every minute or so to rest.  Compared to other competitors in it's class it's also more duty cycle in single phase than any other welder as well with a 35% duty cycle at the full 400A in TIG mode. The welder also has a generous 315A output @ 35% duty cycle in stick mode which means it has enough stick power to tackle almost any common stick fabrication or repair chore with up to 1/4" electrode.  For TIG,the Advanced AC pulse feature this unit is capable of delivering considerably more TIG welding capability (thickness) than any other unit in it's class. This unit is designed to get the job done where thicker plate and weldments are common.  As far as features go, the PowerTIG 400EXT doesn't fall short either.  It has all the familiar features you've come to expect in the EXT digital class of welders from Everlast. as far as basic layout and operation are concerned for those shops that want to upgrade to a heavier unit without retraining personnel.  Duty cycle is a favorable 35% at maximum output and is able to go the distance with its high output constant-on fan design.  As far as low end performance goes, this brute is far from clumsy.  It features a respectable 5A DC and 10A  AC low end operation capability.  Just add a power plug, gas and Tungsten, and you are ready to weld. Now with HV Start. This is an advanced type of HF arc start with electronic control rather than older point gap style starts that required maintenance. Now with Fan-On-Demand. The fan now runs when it is needed, starting on arc start and terminating as the welder cools down enough after the arc stops. This is the 240V 1 and 3 phase version.  For 480V power input, please click here: http://everlastgenerators.com/product/tig-stick/powertig-400ext-480v-3-phase
IGBT Type: Module IGBT
Inverter Type: Digital/Micro-controlled
Output Type:  A D
Voltage/phase:  220/240 V 1/3 PHASE
Max Rated TIG Amps:  400A
Max Rated Stick Amps:  315A
TIG Amps @ Rated Duty Cycle:  4 3 2
Stick Amps @ Rated Duty Cycle:  3 2 2
Max Inrush ( I1MAX ) Amps:  @ @
Maximum Rated (I1EFF ) Input Amps:  @ @
OCV:  60V with VRD: <24V
TIG Output Range DC:  5-400A/10.2-26V
TIG Output Range AC:  10-400A/ 10.4-26V
Stick Ouput Range DC:  20A-315A/20.8V-32.6V
Stick Hot Start Amps:  0-100%
Stick Function:  Adjustable Arc Force Control
Stick Hot Start Type:  Adjustable Hot Start
Stick Hot Start Time:  0-2 Seconds
6010/Cellulose Capable:  Yes
Minimum Amp DC TIG Start:  5A
Minimum Amp AC TIG Start:  10A
TIG Start Type:  L Solid State HF and Lift Start
Memory:  Yes
Start Amp Range:  D A
End Amp Range:  D A
Upslope Time:  0-25 Seconds
Down Slope Time:  0-25 Seconds
Preflow time:  0-25 Seconds
Post Flow Time:  0-50 Seconds
TIG Pulse:  Yes
Standard DC Pulse Frequency:  .1-500 Hz
Standard AC Pulse Frequency:  .1-250Hz Adv. Square Wave
AC Advanced Pulse Frequency:  .1-10Hz
Pulse Time On (Duty Cycle):  3-100%
Pulse Amp Range:  5-95%
AC Frequency (Hz):  20-250Hz
AC Balance Range:  5-90%
AC Wave Forms:  A S T S
Remote Control:  2T/4T with Torch Amptrol settings
Foot Pedal:  Standard
5 year
