SKU# PT-325EXT-480
IGBT Type: | Module IGBT |
Inverter Type: | Digital/Micro-controlled |
Output Type: | A D |
Voltage/phase: | 480 V 3 PHASE (AVAILABLE AS OPTION) |
Max Rated TIG Amps: | 325A |
Max Rated Stick Amps: | 250A |
TIG Amps @ Rated Duty Cycle: | 3 2 1 |
Stick Amps @ Rated Duty Cycle: | 2 2 1 |
Max Inrush ( I1MAX ) Amps: | 14A @ 480V 3 phase |
Maximum Rated (I1EFF ) Input Amps: | 14A @ 460V 3ph |
OCV: | 70V (<24V with VRD) |
TIG Output Range DC: | 5A-325A |
TIG Output Range AC: | 10-325A |
Stick Ouput Range DC: | 20-250A |
Stick Hot Start Amps: | 0-100% |
Stick Function: | Adjustable Arc Force Control |
Stick Hot Start Type: | Adjustable Hot Start |
Stick Hot Start Time: | 0-2 Seconds |
6010/Cellulose Capable: | Limited to 6011 |
Minimum Amp DC TIG Start: | 5A |
Minimum Amp AC TIG Start: | 10A |
TIG Start Type: | L Solid State HF and Lift Start |
Memory: | Yes |
Start Amp Range: | D A |
End Amp Range: | D A |
Upslope Time: | 0-25 Seconds |
Down Slope Time: | 0-25 Seconds |
Preflow time: | 0-25 Seconds |
Post Flow Time: | 0-25 Seconds |
TIG Pulse: | Yes |
Standard DC Pulse Frequency: | .1-500 Hz |
Standard AC Pulse Frequency: | .1-250 Hz |
AC Advanced Pulse Frequency: | .1-10 Hz |
Pulse Time On (Duty Cycle): | 5-95% |
Pulse Amp Range: | 5-100% |
AC Frequency (Hz): | 20-250Hz |
AC Balance Range: | 5-90% |
AC Wave Forms: | A S T S |
Remote Control: | 2T/4T with Torch Amptrol settings |
Foot Pedal: | Standard |
