$0.00
Go to Checkout
SKU# PT-200DV
PowerTIG 200DV
Analog AC/DC
$1,079.00
$809.00
Save - $270.00
PowerTIG 200DV
Analog AC/DC
SKU# PT-200DV
  • Unit Weight: 56 lb
  • Unit Dimensions: 25 in × 15 in × 9.5 in
 A long time standard in the Everlast lineup, the PowerTIG 200 models have been placed in all sorts of demanding conditions since 2009.  It's a favorite among light and medium fabricators who want a simple interface, but still want to have upscale features.  Undoubtedly, the newest version of the PowerTIG 200DV is the best yet.  It is more efficient and power "sipping" than ever.   It also has been fine tuned is more robust than ever.  The new stackable PowerCool 375  cooler matches perfectly to the PowerTIG 200DV and adds to the appeal of the unit. Able to operate on 120V or 240V single phase 50/60Hz, the unit offers maximum go-anywhere performance.  The unit is definitely portable, and can be used with any generator that is rated for 8500W (240V) surge watts and is certified by the manufacturer as "clean power".   If you need a  reliable, TIG welder that you can carry with you and make quality welds day-in and day-out, the PowerTIG 200DV is definitely one to consider.  Now with HV Start. This is an advanced type of HF arc start with electronic control rather than older point gap style starts that required maintenance. Now with Fan On Arc. The fans only run while welding or if an overheat condition has ocurred. Now with Cooler Control Technology.
IGBT Type: Individual IGBT
Inverter Type: Digital/Micro-controlled
Output Type:  A D
Max Rated TIG Amps:  1 2
Max Rated Stick Amps:  1 2
TIG Amps @ Rated Duty Cycle:
120V:
  • 1
  • 1
240V:
  • 2
  • 1
Stick Amps @ Rated Duty Cycle:
120V:
  • 1
  • 8
  • 6
240V:
  • 1
  • 1
  • 1
Max Inrush ( I1MAX ) Amps:  1 2
Maximum Rated (I1EFF ) Input Amps:  1 2
OCV:  T S
TIG Output Range DC:  1 2
TIG Output Range AC:  1 2
Stick Ouput Range DC:  1 2
Stick Function:  Adjustable Arc Force Control
Stick Hot Start Type:  Auto Adaptive Hot Start
6010/Cellulose Capable:  Limited to 6011
Minimum Amp DC TIG Start:  5A
Minimum Amp AC TIG Start:  20A
TIG Start Type:  H L Solid State HF and Lift Start
HF and Lift:  HV Start (Solid State HF Type)
Memory:  No
End Amp Range:  Fixed Minimum
Upslope Time:  Fixed, Minimum
Down Slope Time:  0-25 Seconds
Preflow time:  0-10 Seconds
Post Flow Time:  0-25 Seconds
TIG Pulse:  Yes
Standard DC Pulse Frequency:  .5-150Hz
Standard AC Pulse Frequency:  .5-150Hz
Pulse Time On (Duty Cycle):  10-90%
Pulse Amp Range:  5-95% of welding amps
AC Frequency (Hz):  20-250Hz
AC Balance Range:  20-80% of Electrode Positive
AC Wave Forms:  Advanced Square Wave
Remote Control:  2T/4T
Foot Pedal:  Standard
5 year
