SKU# PT-185DV
IGBT Type: | Individual IGBT |
Inverter Type: | Digital/Micro-controlled |
Output Type: | A D |
Voltage/phase: | DUAL VOLTAGE 120/240 1 PHASE |
Max Rated TIG Amps: | 1 2 |
Max Rated Stick Amps: | 1 2 |
TIG Amps @ Rated Duty Cycle: |
120V:
240V:
Stick Amps @ Rated Duty Cycle: |
120V:
240V:
Max Inrush ( I1MAX ) Amps: | 1 2 |
Maximum Rated (I1EFF ) Input Amps: | 1 2 |
OCV: | T S |
TIG Output Range DC: | 120V: 5A-125A 10.2V-15V |
TIG Output Range AC: | 120V: 20-125A/10.8-15V |
Stick Ouput Range DC: |
DC:
AC:
Stick Hot Start Amps: | Auto regulated |
Stick Function: | Auto Adaptive Arc Force Control |
Stick Hot Start Type: | Auto Adaptive Hot Start |
6010/Cellulose Capable: | Limited to 6011 |
Minimum Amp DC TIG Start: | 5A |
Minimum Amp AC TIG Start: | 20A |
TIG Start Type: | Solid State HF and Lift Start |
HF and Lift: | HV (Solid State HF Type) |
Memory: | No |
Start Amp Range: | Fixed, Minimum |
End Amp Range: | Fixed/minimum |
Upslope Time: | Fixed, Minimum |
Down Slope Time: | 0-10 Seconds |
Preflow time: | Preset/Auto .3 Seconds |
Post Flow Time: | 0-25 Seconds |
TIG Pulse: | Yes |
Standard DC Pulse Frequency: | 1 or 50 Hz |
Standard AC Pulse Frequency: | 1 or 50 Hz |
Pulse Time On (Duty Cycle): | Fixed/Preset |
Pulse Amp Range: | Fixed/Preset |
AC Frequency (Hz): | 20-250Hz |
AC Balance Range: | 10-90% of Positive |
AC Wave Forms: | Advanced Square Wave |
Remote Control: | 2T/4T |
Foot Pedal: | Optional |
