SKU# PP-102i
Type: | IGBT |
Voltage/phase: | 480 V 3 PHASE (AVAILABLE AS OPTION) |
Output Amp/Volt Range: | 20-100A/88-120V |
OCV: | 300V |
Max Inrush ( I1MAX ) Amps: | 4 |
Maximum Rated (I1EFF ) Input Amps: | 480V 3 Phase: 17A |
Duty Cycle At Rated Amps/Volts: | 6 1 |
Arc Start Type: | Blow Back (Piston type) |
PilotArc: | Yes |
Torch Type: | Genuine Innotec iPT100 |
CNC Interface Port: | Yes |
Adjustable Post Flow Timer: | Yes |
Gouging: | Yes |
Recommended Cutting Air Pressure: | 65-72 psi |
Recommended Compressor Capacity: | Minimum of 9 CFM @90 psi, 60-80 gallon tank |
OK-to-Cut Indicator/Low Air pressure safety: | Yes |
Downloads
