SKU# PA-280STH
IGBT Type: | Module IGBT |
Inverter Type: | Digital/Micro-controlled |
Output Type: | D D |
Voltage/phase: | 220/240 V 1/3 PHASE |
Max Rated TIG Amps: | 280A |
Max Rated Stick Amps: | 250A |
TIG Amps @ Rated Duty Cycle: | 280 @ 35% Duty Cycle |
Stick Amps @ Rated Duty Cycle: | 250A @ 35% Duty Cycle |
Max Inrush ( I1MAX ) Amps: | 2 2 |
Maximum Rated (I1EFF ) Input Amps: | 2 2 |
OCV: | 70V (VRD<24V) |
TIG Output Range DC: | 5A-280A/10.2V-21.2V |
Stick Ouput Range DC: | 20A-250A/20.8V-30V |
Stick Hot Start Amps: | 0-100% |
Stick Function: | Adjustable Arc Force Control |
Stick Hot Start Type: | Adjustable Hot Start |
Stick Hot Start Time: | 0-2 Seconds |
6010/Cellulose Capable: | Yes |
Minimum Amp DC TIG Start: | 5A |
TIG Start Type: | HF and Lift Start |
Memory: | No |
Start Amp Range: | 5-280A |
End Amp Range: | 5-280A |
Upslope Time: | 0-25 Seconds |
Down Slope Time: | 0-25 Seconds |
Preflow time: | 0-25 Seconds |
Post Flow Time: | 0-50S |
TIG Pulse: | Yes |
Standard DC Pulse Frequency: | 0-250 Hz |
Pulse Time On (Duty Cycle): | 5-95% |
Pulse Amp Range: | 5-95% |
Remote Control: | 2T/4T with Torch Amptrol settings |
Foot Pedal: | Standard |
