$0.00
Go to Checkout
SKU# PA-200STI
PowerArc 200STi
DC Stick/DC Live Lift TIG
$359.00
$319.00
Save - $40.00
PowerArc 200STi
SKU# PA-200STI
  • Unit Weight: 25 lb
  • Unit Dimensions: 16 in × 13 in × 7 in
The all new PowerARC 200STi is built with the true professional in mind.  With 200 amps of DC Stick/Live Lift TIG welding power, the new compact digitally controlled IGBT inverter welder cuts no corners on performance or design.  The unit features E6010 welding capability making the welder suitable for use on pipelines, shipyards, construction sites, portable repair jobs and pressure and container vessels, and any place requiring the use of E6010 and related cellulose-based welding rods.   For excellent low spatter arc performance on E7018, E7024, E7014 and even stainless class electrodes the unit features another connector port for all other welding rods.   In both the 6010 and standard operating modes, the successor to the PowerARC 200ST now features adjustable Hot Start, and adjustable arc force control, which gives you the amount of arc control you need in almost any situation.   The basic DC Live Lift TIG capability of this unit also allows the unit to perform well on steel and stainless applications.  Although this unit is built for pros who demand the most from their welder, the PowerARC 200STi feels at home, on the farm, or in the hobbiest's  garage and features 120V/240V dual voltage operation.  Be sure to pick up a 17 gas valve TIG torch and gas regulator if you want to TIG weld with this unit.  Check out our 17V series TIG torch and gas regulator located in our accessories section which are ideal for this unit if you need to use the TIG function.
IGBT Type: Individual IGBT
Inverter Type: Digital/Micro-controlled
Output Type:  D D
Max Rated TIG Amps:  1 2
Max Rated Stick Amps:  1 2
Stick Amps @ Rated Duty Cycle:
120V:
  • 1
  • 9
  • 7
240V:
  • 2
  • 1
  • 1
Max Inrush ( I1MAX ) Amps:  @ @
Maximum Rated (I1EFF ) Input Amps:  @ @
OCV:  S T
Stick Ouput Range DC:  1 2
Stick Function:  Adjustable Arc Force Control
Stick Hot Start Type:  Adjustable Hot Start
Stick Hot Start Time:  0-2 Seconds
6010/Cellulose Capable:  Yes
Minimum Amp DC TIG Start:  10 Amps
TIG Start Type:  Live Lift TIG Only Lift Start only
Memory:  No
TIG Pulse:  No
Foot Pedal:  None/Not Applicable
5 year
